- Sep 28, 2018
When you say “at 75mm” I assume you mean by cropping?side by side comparison with the Q3 @75mm and the Q3 43 @75mm to show the difference in Bokeh between the two lenses both cropped to 75mm:
So the Q3/43 has a 50mm lens?yes. The DOF is of course the DOf of a 50/2.0 and the other image from a 28/2.0. With cropping the DOF does not change. But still there is a significant differenece in the DOF of a 28mm vs. a 50mm lens.
My guess is that the DOF of the Q3 43 cropped at 75mm has a similar result like inbetween a MFT and an APS-C camera with a 75mm lens.
Yes, agreed. If you keep the same subject distance and aperture but change the focal length then you will change the DOF. Cropping makes no difference.No, 43mm. That was a typo. I will correct it. I could one day comparison shots with the Lumix MFT 42,5/1.7 or Leica 42,5/1.2. We will not find an exact replication. But it is good to know in whioch bullpark the DOF will be if the 43mm lens of the Q3 43 is cropped to 75mm.
The DOF itself does not change if you crop the image. It is still the DOF of a 43mm lens. Like if you would do it later in post.
My Xiaomi Poco F6 came with a 90W charger with USB-A socket. This can charge anything with a change of cable or cable adapter.Actually, it seems that the EU directive does not ban chargers per se, but its objectives are to reduce the number of surplus chargers in circulation. As such, it DOES mandate:
- Only devices with a USB C charge port can be sold in the EU from Dec 24
- Products must be offered to consumers with the charger unbundled
Pixel 8 Pro only had a cable provided. I then bought a wireless charger for it that only phones with that capability can use. Most people are then buying these or more powerful USB power adapters if they don't already own them.The last point doesn't actually say you can't provide a charger, but it seems most manufacturers are treating it that way - you either buy it unbundled or you don't buy it at all!
The only think I can thank them for is my higher blood pressure, my lighter wallet, and the removal of my rights as an EU citizen!So it's all a bit daft and you should thank Nigel and Boris for helping you escape![]()
BUT: if Leica decides one day to release a Q without lens, just offering L-mount connection, I think the devil will be very big and very demanding
Say that on Leica forums what happens? They as mad as Pentax?As a side note: the aperture ring on all Sigma i-series lenses feel a lot more high quality/ Leica like than the aperture ring of the Leica Q3 43.
Kudos to Sigma.
Hey those Pixel 8 Pro images are great.... My mother now has one
I'm nearly tempted and that's worrying
