PJD
- May 11, 2024
I'm not sure if I misunderstand how the noise reduction features in my new S5iiX camera work, or if maybe there's a bug. The camera has the new 2.0 firmware installed.
I'm not noticing any significant change in carefully-shot 24MP RAW test images when I set "[Camera] | Image Quality 1 | Long exposure NR" = ON, and "Quick Menu | NR" = [_ANY_ value].
To see what or if the camera's NR function does, I locked my camera on a tripod and purposely shot at ISO 6400 in a darkened room so I could set exposure for about 4 seconds. I shot in manual mode, with "iA" turned off, Standard photo style, nothing automatic except for focus & a 2-sec shutter delay.
For the first image I set the Quick Menu | NR to zero, and then shot several additional images, each with QM | NR = +1, +2, +3, etc., and also -1, -2, -3, etc. After each shutter press, the camera displays a message saying the long exposure noise reduction process is taking place.
When I look at the resulting images at 100% view on my Mac in the latest versions of both Affinity Photo 2 and Pixelmator Pro (with _NO_ corrections performed on the images), the images all look "essentially" identical. As expected, individual pixels shift a tiny bit from image to image, but there's no obvious noise reduction/removal. I'd expect the -5 and +5 to look very different than the "zero NR" image, but they're not.
So, is this user error? Anyone else seeing similar results?
(Meanwhile, two points: I don't usually shoot at ISO 6400, but did so for this test. And: Affinity Photo 2's noise reduction feature works really well, so I'll probably rely on it instead of whatever the camera can do. But I'm curious what the camera is capable of.)
