Introducing the Zeus compact primes (dreamer edition)
robin0112358
First company to make compact and light primes wins my wallet. If they could do it in 1980 they can do it now. Sigma has made an attempt, but the Contemporary line are still much larger than comparable vintage lenses. And some are heavier than the Lumix equivalent.
Features:
  • an aperture ring for tactile control
  • Zeiss looks, by which I mean sleek and simple
  • short metal hoods instead of giant plastic monsters
  • auto-focus, so there's a reason to buy them
  • no need to make them all the same size
Unique focal lengths could be chosen, so the new lenses don't conflict with the existing offering. This triumvirate would be a good start:
  • ZEUS 28mm F2.8
  • ZEUS 43mm F2
  • ZEUS 105mm F2.8
People will say "I want faster" but the idea here is to be "fast enough" and small.
That is oversimplified.
In 1980 only film was used. By the relative weak film quality. It was what it was.
Today lenses has to deal by the characteristics of digital sensors.
By the high resolution of today's sensor possibilities, standards are pumped up.
At the other side lens designers also have to take into account the disadvantages of most digital sensors.
If "no use" of high grade special micro-prism overlays are used (like Leica do).
Corner quality deteriorates if lenses are to short to the sensor surface.
Well not difficult to understand. Comparable vintage lenses don't come to the same optical quality.
And "if" these vintage lenses have AF. They are much slower than today's lenses with internal focus.
Plastic versus metal components can make a difference by weight. Real glass versus plastic lens parts as well.
Lens design always is a compromise.
If not by optical means, than by weight - dimensions or lack of fast AF.
Indeed, since this is not an optics forum! But the basic premise is sound.
Your prognosis is too dire. I get excellent photos with lenses from the manual focus era. Indeed, many of these have escalated in price since they are so commonly converted for cinema use. Lenses from Zeiss and many other firms resolve just fine on digital sensors despite the technical challenges. (This is true even on 100 megapixel sensors.)
Fast AF is not a priority. This is not a set targeted at sports shooters, birders, etc. These markets are already well-served. Why do all lenses need to be designed for the same people? They don't. My screw-focus Pentax lenses worked just fine on DSLRs. Some are miniscule. In the decades since, lens tech has moved on substantially but still we have no replacements for the smaller vintage form factor.
With the S-9 released there will be increased demand for smaller lenses. Though, yes, in that case people without the technical skills (apparently the target market) will demand AI-like levels of AF... as many people already do. Admittedly, that particular market stands in contradiction to my own constraints.
BTW, there are other reasons for the trend to large lenses besides optical necessity. I might blame Canon for starting the "bigger = professional" model that many people still ascribe to. It's a masculine bragging thing.
No, it is just my experience over the years.
But keep in mind everyone do have other expectations.
Me to, but just "for some lenses" when I have the possibility to close down aperture values for about 2-3 stops.
Most of my older manual lenses (some "famous" by their quality in those times) doesn't match up any longer.
Maybe not for you. But depends what kind of subjects.
I am not a sports shooter, birders, etc. - Just only need "fast" AF for portraiture / people photography at wide open aperture values.
F1.4 - F2 - F2.8 by eye detection.
By the very thin DOF to difficult to fiddle around to struggle by manual focus.
My eye sight is also not that good any-more at my age.
All older "fast" lenses are not good enough by optics. To use wide open or just one aperture value stopped down.
But also can be dependant to your "artistic" approach. For some kind of photography you only want imaging "atmosphere".
Experiences differ. Characteristics other than razor sharpness are valued by many photographers... amateur and pro alike. I have seen plenty of incredible photos taken on digital sensors with old Zeiss, Leica, and Pentax glass. Even wide open. You can keep asserting that it's impossible, but the evidence is there!
Tell me these photos don't blow your mind: David Zimand.
I agree that thin DOF is hard to manage but AF is not a panacea. The eye is not where you want focus to be often enough, since the nose lies in front of that plane! Just to take one example.
My eyesight sucks, by the way, but I have got a lot more joy from photography by focusing on the subject... pun intended!
OK, so I don't pay much attention to Nikon but just discovered that they are now producing compact primes for their Z system. Though these are missing aperture rings, they prove that large lenses are not necessary (so long as other constraints are allowed). Two of these specs coincide with my fanciful Zeus set. It will be interesting to see if they add a portrait lens and how small it might be.
Nikkor Z 26mm f/2.8 (€450)
24mm deep / 125g
Nikkor Z 28mm f/2.8 (€260)
44mm deep / 157g
Nikkor Z 40mm f/2 (€260)
46mm deep / 170g
Characteristics other than razor sharpness are valued by many photographer... amateur and pro alike
Yes, all kinds off characteristics by out of focus areas, in front or behind the focus point. Different for both sides.
Chromatic aberrations, astigmatism, field curvature, coma, flare.
All "can" be part of an "artistic" approach. In which imaging "atmosphere" gives a more appealing look to images.
But in general, all my new lenses are better than my early past lenses.
It is more easy to "deteriorate" clinical sharp images by all kinds of digital or "real" hardware like filters to get your "artistic" characteristics.
Than the other way round to improve bad pictures by lack of sharpness and having all kinds of optical errors.
Well, in no portrait do I find the nose more important than the eyes. :cool:
Maybe for those few exceptions where someone has such a unique nose to focus on it,
I would rather make that exception for that, to switch off the AF, and then perhaps focus it "manually". ;)
Yup. Or take these, which are plenty sharp enough to satisfy me, using an old Vivitar 28/2.5 (made by Kiron) on my Sigma fp:
53757165645_3af8ffa011_h.jpg20240518-SDIM0416 by Travis Butler, on Flickr
53319871123_1e18ec52ef_h.jpg20231102-SDIM7948 by Travis Butler, on Flickr
53475078229_974a598aaa_h.jpg20240117-SDIM8870 by Travis Butler, on Flickr
53527792419_a06ced79ac_h.jpg20240209-SDIM9017 by Travis Butler, on Flickr
53703345592_82c42ab66f_h.jpg20230709-P1011711 by Travis Butler, on Flickr
53423691383_6816ac999e_h.jpg20231201-SDIM8429 by Travis Butler, on Flickr
Several of these highlight something that's more important to me than absolute razor-sharpness: tonality and color. I like rich color, but more important, I like the ability to capture and render very fine tonal graduations - the gloss on a waxed fender, the puffiness of a cloud. That's something missing from a lot of modern lenses, which are very sharp but 'flat' in their tonal rendering.
Yeah, mine's not too great these days either. Focus peaking and good diopter adjustment on the EVF is my friend.
    EXIF
Agree completely.
I currently leave the house with a Pentax-M 50/1.7 and Pentax-A 28/2.8 which together are the size of one Panasonic prime. They render very nicely.
Would that be this lens? I pretty much "wrote the book" on the Vivitar 28mmm line... as you may already know!
The only thing I'll say -small plus MF & Aperture rings don't really go together. Small & a focus ring is fine, it starts to get clumsy beyond that.
And with modern focus aids such as focus peaking & picture in picture magnification, MF is a walk in the park
Eh… for counterexamples, I’d point out the Pentax-M 40/2.8, Contax 45/2.8, and OM Zuiko 40/2… or for somewhat less extreme examples, the Konica Hexanon 40/1.8 and Minolta 45/2.
I own all but the Olympus… and while I’ll admit the Pentax and Contax can be more difficult to handle, they’re still perfectly usable. (As opposed to the Industar 69, which is damn near unusable…) The Konica and Minolta handle as well as any other film-era lens I’ve ever used. I’ve used both the Pentax and the Contax as the lens-left-mounted on my Sigma fp, and the Konica’s currently in that slot.
(Back in 2019, I was in Orlando for a developer conference, and I had a chance to pick up the Olympus for $400 at a local camera shop… I passed because I’d already spent a bunch on visiting Kennedy Space Center. I’ve been kicking myself for that ever since.)
Those Nikon Z primes show that it can be done. But will any of the L mount lens makers do it?
Definitely looking forward to that happening! The Nikon Z "pancake/cupcake" lenses are very good.
And the Viltrox lenses for Z mount are excellent as well as small, light, and very inexpensive. Daumenhoch
Reviving this thread to hype two 85mm SLR lenses that I now use, since there weren't many examples of portrait lenses in the thread so far. These compact primes have amazing image quality, more than usable from wide open.
Olympus Zuiko AUTO-T 85mm f/2, 48mm long, 280g, 49mm filter
Carl Zeiss T* Sonnar 85mm f/2.8, 48mm long, 245g, 55mm filter
Compare with:
Lumix S 85mm f/1.8, 82mm, 355g, 67mm filter
Compare with:
Would I swap my Lumix 85mm just to save 80 grams? Not a hope in hell. People forget that the Lumix primes are all similar size and weight, for a particular, very good reason
My (lack of) money's on Samyang. Maybe 7Artisans, but first I'd like to see those September images of 35+40mm AFs become .. lenses?
In the meantime I also toy with Pentax primes, including their aps/c 40+70mm offerings. They nearly cover the 36x24 frame, and as I shoot 4:3 they lose the worst bits right off. The smc-m 135/3.5 is pleasantly small too.
No-one forgets that... but I am not using a gimbal nor large video rigs with barn doors. And if I was, I wouldn't be choosing a Lumix system as my back end!
It's not the weight so much as the size. A lens half as long means I can carry more in the bag.
The idea here is to provide an alternative. Not to replace any lenses that exist currently. It seems that what people forget is that other people have different priorities, use cases, and opinions. Even though in the OP it's clearly stated what the focal lengths might be.
And yet that's what Panasonic specialises in, and the market they're chasing as they find it profitable.
