Pete_W
- Mar 22, 2023
Same for me on the S5II. C-AF works so reliably that I just leave it there.I quit using SAF quite a while ago and only use CAF.
I think that's wrong. Theoretically DFD CDAF should have better accuracy than PDAF. The big advantage of pdaf is, that it can detect direction and estimate distance for focusing. But PDAF can't tell you if something actually is in focus. CDAF based focus on the other hand can tell you if something is in focus, but it can't tell you in what direction and how far an out of focus object is.Since s5II always on the C-af since s-af is dfd (contrast based) and wil surely misfocus way more than c-af. especially in low contrast scenes.
That's exactly the problem I've been experiencing.An interesting comment by georgehudetz on the DPReview thread that links to this one:
https://www.dpreview.com/forums/post/67586167
Looking through the photos where I've had less than perfect sharpness the AF area has always been on a subject that had some significant variation in depth, such as tree branches or leaves, and the detail within the AF area has been comparatively fine. But that variation should never have been significant enough for the available DOF not to include the subject.
CDAF algorithms use something called the "focus measure" function to return a numerical value representing the degree of focus in the focus zone. It works by calculating the edge contrast and the idea is that the lens's focus is shifted while the focus function's value is read. When the focus function is at a maxima, the focus movement stops. Clearly, when the detail approaches that of the sensor's pixel pitch there will be no edges and no easy maxima to find. But the subject I used in the focus area had details that were much bigger than the sensor pitch. You can see that in the 100% grabs.I've certainly seen CDAF fail when detail in the subject approaches the resolution of the sensor; I wonder if this is a similar situation?
I think the joke was aimed at you Pete.I know you're joking but I'd like the train detection!!!
I thought both DFD CDAD and PDAF could be used simultaneously but I'm only a debutante with S5ii and MILC.I think that's wrong. Theoretically DFD CDAF should have better accuracy than PDAF. The big advantage of pdaf is, that it can detect direction and estimate distance for focusing. But PDAF can't tell you if something actually is in focus. CDAF based focus on the other hand can tell you if something is in focus, but it can't tell you in what direction and how far an out of focus object is.
That's why PDAF is much better for tracking and CDAF should be better for accurate focusing. That's why also other manufacturers combining both technologies.
As I understand it, PDAF is used to estimate distance and direction of subject movement ie towards or away from the camera, CDAF does the final tweak for maximum accuracy. DFD is just a means by which the camera looks at the out of focus areas, to determine which direction to drive the focusing elements in, using contrast only.I thought both DFD CDAD and PDAF could be used simultaneously but I'm only a debutante with S5ii and MILC.
That's my understanding too.As I understand it, PDAF is used to estimate distance and direction of subject movement ie towards or away from the camera, CDAF does the final tweak for maximum accuracy. DFD is just a means by which the camera looks at the out of focus areas, to determine which direction to drive the focusing elements in, using contrast only.
I think what's going on is that as the focal length increases the required focus precision increases too. I suspect that it follows the same mathematical relationship as the hyperfocal distance - that is, the precision needed will increase with the square of the focal length.
