Test/ First Impression 7Artisans 10mm f/2.8 Mark 2 Fisheye
SimonC
As it is so inexpensive, and as it’s been getting such good reviews from reliable sources, I thought I’d try the new mark 2 version of 7Artisans 10mm f/2.8 fisheye lens. It’s solidly built and quite hefty, weighing in at over 600g, but it balances reasonably well on the S5II. It is a fully manual lens, and although fisheye lenses are often said to need little in the way of focusing, with the combination of f/2.8 and a minimum focusing distance of 15cm from the focus plane, which translates to about 4.5cm from the end of the lens, close-up photography needs some concentration! The focus ring and the aperture ring are nicely damped; the only negative is that the aperture ring only turns smoothly, with no clicks.
At very close focus distances the field of curvature is extremAe (see snaps below) but at greater distances there is no problem, especially when stopped down.
I haven’t had the opportunity yet to do any serious shooting, but I’ve attached a few shots to give an impression of what this lens can do. These shots are either at f/2.8 or at f/11. It should be obvious which is which!
  • Panasonic - DC-S5M2
  • 10.0 mm
  • 1/500 sec
Finally, a brick-wall shot! This is from minimum focus distance, showing the huge curvature of field at this distance.
  • 10.0 mm
  • 1/320 sec
That looks like a fun lens to me! Earlier this week I was thinking about it :) But I must first use the stuff I have more :cool:
Heh. The one indulgence I bought from my tax refund was the TTArtisans fisheye Paul uses… supposed to arrive today, coincidentally. Looking forward to being able to compare and contrast!
Ooo.... I can think of a ton of places I could have a blast shooting Live Composite with this.
A question: Is there a spot for a filter in the mounting base? I'll just assume a filter on the front of the thing is totally out of the question.
The TTArtisan did indeed arrive today; I've only had a chance to shoot it outside on my street, but so far very impressed. :) Fisheyes unite!
That photo of the Treasurer's House is superb. How about the Chapter House ceiling (and windows)? ;)
I haven't been back to the Minster since I moved from MFT to full-frame - I really must, it is just down the road, after all! But as compensation here are a couple taken on my GX-80 with the Samsung 7.5mm fisheye and with the PanaLeica 15mm.
  • Panasonic - DMC-GX80
  • NO-LENS
  • 1/125 sec
  • Auto bracket
  • ISO 2500
  • LEICA DG SUMMILUX 15/F1.7
  • 15.0 mm
  • ƒ/1.7
  • 1/60 sec
  • Auto bracket
  • ISO 800
Wow! Thanks for posting those, they're beautiful. And great use of the fisheye lens.
