sergun80
- Sep 3, 2024
Surprise...
The source has already published an image of this lens. It is designed for full-frame cameras and is capable of focusing as close as 0.36 m to the subject.
The filter diameter, as indicated by the markings, is 58mm.
The Viltrox AF 28mm F/1.8 II EVO has two control rings: a focus (wide) ring and an aperture (narrow) ring. A switch for auto/manual focusing is located on the side of the lens barrel.
This moderately wide-angle lens allows you to capture wide shots and even isolate your main subjects from the background thanks to its fast f/1.8 aperture. It's also relatively compact, as evidenced by the published image. The price has not yet been announced. However, the Viltrox 28mm F/1.8 II EVO will be released on July 15th. All the details will be revealed soon.
