Top selling cameras of 2024 (in Japan)
No L Mount in top ten, nor m43. Panasonic won’t be happy.
Fuji seem to be doing something right though - three models in the top five (goodness knows why, I’ve never found any Fuji camera appealing).
Very intetesting, Paul. I would like to know the total in the whole world, not only from a japanese Shop. But I don't know, maybe this information can be extrapolated to Japan or to the Asian market.
Yesterday I watched this video about nature photography with the Lumix S5 ii and it is a totally underrated camera for photography in general. Furthermore, this photographer only uses 2 lenses, the 20-60mm and the 70-300mm (along with the 85mm f1.8 for portraits):
Nice images. Awful music !!
I find some VERY appealing, but I don't have 10K for a used body and two lenses. (Medium format, obviously.)
Ah yes, I'd forgotten about their MF stuff. That could interest me - at least it's not X Trans.
I am curious to know what the issue is with x-trans sensors, Paul.
I've never owned a Fujifilm camera but "reviewers" like Chris and Jordan have always rated them highly. Given my recent comments about C & J, maybe that's a clue!! Z04 Flucht
Adobe never used to play well with the Fuji files. Google Fujifilm works. Silkypix did, but most people hate Silkypix for some reason. Well, it's mostly because it's (Silkypix) a bit different to use than Lightroom/Photoshop, & lots of people hate different.
Apparently later versions of Adobe software work better, bit the stigma seems to hang around.
I tried an XE2 back in the day. 16Mp XTrans. I found the following when processing raw files with Lightroom:
- Mushy greens, especially evident with fine foliage (e.g. distant trees)
- A tendency to show “worms” if sharpened even a little too much
- Baked-in NR at even moderate ISO levels
People said that the only decent raw processor back then was Irridient, but I wasn’t going to change my workflow since I didn’t find the XE2 overly appealing in other ways - AF was so-so, the build of the body was poor, and I didn’t like the handling. But, the 30mm f1.4 lens I used with it was superb.
It seems to me that XTrans brings downsides for no upsides. The original objective of it was to reduce moiré without the need for a OLPF. But increasing pixel counts on Bayer sensors have pretty much fixed that problem without the need for an OPLF. All other manufacturers now use regular Bayer sensors without OLPF and there is no real world issue with moiré. Even Fuji tacitly admit it’s a pointless exercise since their low end and high end models don’t use it.
If you use SOOC JPEGs then it won’t bother you, but for raw, you need to choose the right PP package to get the best out of the sensor and I really don’t want to go that route.
Thanks. I use DxO PhotoLab and from what I've read, it also wasn't considered to be very good with x-trans raw files until more recently.
Thanks for the info.
When I was looking to move away from m4/3, I considered a range of cameras and narrowed it down to two - the Lumix S5 and the Fuji XT4. I was attracted to the Fuji controls and design but didn't know much about x-trans or the lenses available. I spent some time in the DPR Fuji forum but found quite a bit of conflicting information about the sensor. I saw complaints about foliage and worms, yet others claimed it was not an issue. Same with some of the lenses - I was interested in a few of the standard zooms but found some quite polarised views about quality and sharpness. I eventually went into a camera store to hold and try both cameras and the S5 was so much better ergonomically. Being a Lumix m4/3 user I decided it would be an easy upgrade as the menus and layout were very similar to what I was using.
Yes, the old-style aperture ring and shutter speed dial is definitely retro, but the PASM approach is actually way more useable.
I've owned three Fujis: X-Pro1, X-Pro2 and X-T2, with the X-Pro2 being one of my all-time favorite cameras. I'd have likely stuck with them if not for the stupid design of the X-Pro3: they removed a load of buttons so you had to use the touchscreen, then they hid the touchscreen (that daft hidden, fold down design with the ribbon cable that tends to fail) and justified it with a load of waffle about "pure photography". :mad:
As Marcus said, the foliage worms are very dependent on the software you use to process the images. Iridient Developer or X-Transformer don't have the problem and can pull a remarkable amount of detail from the files. Other software was a bit of a mix with early support in Adobe products being particularly bad, and DXO not supporting XTrans cameras at all. It's not so much of a problem now.
As to the retro controls, I like them. One glance at the camera and you can see how it's set up, plus Fuji's system of putting an 'A' (auto) position on the aperture, shutter speed and ISO makes a heck of a lot more sense than Nikon's dials plus PSAM on the Zf and Zfc. Plus I did use the X-Pro's hybrid viewfinder a lot of the time, although that's something else they watered down on the X-Pro3 where it lost the dual magnification ability and so was useless for wide angle lenses.
Having aperture rings is one of the (many) reasons why I like the Sigma i-series primes so much...
Thanks Alan.
I was quite tempted by the retro controls on the XT4 as they reminded me of my first SLR, a manual Praktica camera, where I could easily see the settings.
One of the biggest benefits of mirrorless cameras for me is the ability to see everything related to exposure permanently displayed in the viewfinder - aperture, shutter speed, ISO, over/under indicators/histogram. I can then adjust everything needed using the top dials without removing the camera from my eye. Having to lower the camera and look at physical dials seems a backward step to me.
I can't say that I ever remember having to do that other than for changing ISO on the X-Pro2 where you have to pull up and turn the ring round the shutter speed dial. I could, and did, change the ISO / shutter speed / aperture / exposure compensation on the X-T2 with the viewfinder to my eye, and the displays are much the same as for any other mirrorless camera. It did take two hands to change the ISO with the dial on the left, though.
I'm happy using either system, and both have their advantages and disadvantages, but given the choice I'd go for a camera with the retro controls.
Thanks Alan.
I had a Fuji X-S10 (pasm style) first, really liked the camera, but it was not WR and battery life was not that good but ok with a spare. All the time I was eyeing the X-T4, same sensor, but bigger evf and those retro dial approach, WR and bigger better battery. 2 months before my trip to Peru I traded in my X-S10 I had for 2,5 year or so for an 2nd hand X-T4 because jungle, desert and ocean justified having WR (all lenses with me were WR as well). In the end, I didn't care for the dials. I use Aperture priority 95% of the time and auto ISO. So 2 out of 3 dials were already redundant. For me, the upgrade was worth it, better viewfinder (about the same as S5ii), better AF, WR and battery. Downside was the weight increase. Anyway, 3 months later I traded all my Fuji gear in and got my S5ii.
Looking back, I should have traded in my X-S10 for the S5. Lot of pictures were taken in mid sunny daylight with huge DR, and Fuji is not as good in that situation as the S5 is.
I used the free Fuji version of Capture One Pro, and that one is really really good. I actually would rather use C1 Pro then Lightroom as I do now, but those prices are insane for a hobbyist. Photolab was not good at Fuji files, but ok. I got Photolab 6 for my GR3x (changed it later to the GR3 I have now) and that was awesome for the GR3x, but latest updates on PL6 and PL7 gave me horrible experiences, the default profile was so bad that I had to PP every single raw photo from then on. It was even more horrid on S5ii files, so I took my loss and went with Lightroom.
I used the Fuji 16-80/4 WR a lot in Peru, but the 24-105 is WAY better... :)
Thanks, that's an interesting journey. I suspect that while I liked the idea of the retro dials it would be the same for me, i.e. I am usually in Aperture priority with floating ISO so PASM is a better option for the way I shoot.
I am intrigued that you didn't like how DxO PhotoLab processed your S5II files. I've been using DxO for about 8 years since it was Optics Pro through all the versions and name chanhge to PhotoLab. I am using the current release (v.8) and I also have Filmpack and Viewpoint installed.
I have never used Lightroom and while I am interested to see what it's like, I haven't tried it out because I figure it will take a long time to learn it from scratch. I feel that PL works well with the S5II but I am only an intermediate user, still learning how to use the more advanced features.
I don't think a manufacturer needs to be in the top ten just to maintain profitability so I'm not worried. The only S camera that Panasonic have released this year is the S9, which has been disappointing for a lot of people, so no surprise there really. Any S1 replacement will likely be expensive compared to the S5 II or S9 so unlikely to make a large dent in the sales chart for 2025 either.
I really like the Fujifilm cameras I've used, and their lenses too, though their biggest problems are that they're overpriced for APS-C, most models are not weather sealed and many don't have IBIS. If they had a FF line then I certainly would have given them strong consideration before my switch.
