New Firmware V5.0 for Leica SL and Q Range
xaviergut
In this video from Leica Camera Australia (), Nick Rains breaks down the key features of the Firmware V5.0 update for the Leica SL and Leica Q camera ranges [00:00].
Focus Bracketing (SL & Q Cameras)​
  • How it Works: Located in the drive menu, this feature automatically shoots a series of frames while shifting the focus point in predictable increments [02:11]. You can customize the step size, the number of frames, and the sequence order—either starting at your focus point and moving progressively further away (0+), or alternating behind and in front of your focus point (0+-) [02:28].
  • Step Size Calculation: The camera calculates step sizes based on the depth of field at your focus distance using a strict 0.01 mm circle of confusion (tailored for high-resolution 60-megapixel sensors) [05:30]. As a rule of thumb, setting the step size to 5 moves the focus point by roughly one depth-of-field unit per shot [06:09].
  • Creative Advantage: Focus stacking these brackets allows you to achieve deep sharpness across a close-up subject while shooting at wider apertures (like f/2.8 or f/4), preserving a soft, out-of-focus background rather than dealing with the busy backgrounds caused by stopping down to f/16 [09:06].
SL-Specific Updates​
  • Pre-Shot Capture: When half-pressing the shutter button in electronic shutter mode, the camera continuously buffers frames for 0.5, 1, or 1.5 seconds before you fully press the shutter [11:34]. This helps capture fast, unpredictable action—like a bird taking flight—that would otherwise be missed due to human reaction times [12:33]. Note that pre-shot frames count toward the camera's total buffer limit [13:27].
  • Sensor Dust Protection: You can now configure the mechanical shutter to close automatically when powering down the camera to protect the sensor from dust [14:45].
  • Third-Party L-Mount Lens Support: Programmable function buttons built into large third-party telephoto lenses are now supported [15:05].
  • Sharper Magnified Live View: Viewfinder resolution when zooming in to check manual focus has been increased by a factor of four [15:37].
Q-Specific Updates & Shared Improvements​
  • AF Detection Toggle (SL & Q): You can now assign a function button to instantly toggle subject detection (such as face or car detection) on and off, allowing you to quickly revert to traditional field or spot focusing in crowded scenes [15:56].
  • New Video Codecs (Q): Lower bit-rate video codecs have been added to make video workflows more manageable [17:04].
  • Car Detection & HDMI Mirroring (Q): The Q range now matches the SL range by adding car detection to its autofocus modes, as well as full HDMI mirroring that displays camera menu data and overlays on external monitors [17:10].
I wish Panasonic would do the same tweak to viewfinder sharpening when zooming in. I find the S1Rii’s magnified view quite grainy.
I wish the Leica SL cameras would have the live view composite feature of the Lumix full frame cameras...
