PJD
- May 11, 2024
Zoom range (shot from the same position)View attachment 4527
Hi jomppak: Where is this railroad station located?
It is in Finland (Tampere). Actually it is an old pulp mill which now has tram tracks going through the mill area.Hi jomppak: Where is this railroad station located?
Why waited so l longI finally broke down and got the 28-200mm, and am really looking forward to using it. Hope I got a good copy; my first test shots look good.
Thanks so much, Pete! I'm not used to shooting at such high ISO settings, and when I first processed them I had issues downloading the DXO profiles so I just used normal sharpening and clarity when importing into capture one. I may go back and play with settings a little more and see if using the lens profiles help for 1:1 viewingThe photos all look acceptably sharp to me, Tim! Really nice light.
In our church I also use the 28-200 sometimes, although I try to handle it with one with my primes or the 20-60.Thanks so much, Pete! I'm not used to shooting at such high ISO settings, and when I first processed them I had issues downloading the DXO profiles so I just used normal sharpening and clarity when importing into capture one. I may go back and play with settings a little more and see if using the lens profiles help for 1:1 viewing![]()
Hmm did you have issues with banding or was it something else?In our church I also use the 28-200 sometimes, although I try to handle it with one with my primes or the 20-60.
However, I did have some problems with the electronic shutter (for not disturbing the congregation) and low light.
Actually I only see it in the shots made with my 50mm or 85mm primes... So It looks I'm mistaken in this.Here an example of the banding problems
(Using "SynchroScan" at max. 1/120s I got rid of banding - check it out...)
Some butterfly crops made by S9+28-200 ...
Only in certain - not every - artificial light.Does the banding issue you're discussing sometimes happen in natural daylight AND in certain artificial light?
Cool. I was confused by your comment being in the same post with daylight photos of butterflies. Thanks for clarifying. Cheers!Only in certain - not every - artificial light.
It's not a lens that I need (I love my 24-105 and 70-300 lenses) but I have seen some really good photos taken with the 28-200mm lens. I guess if you do a little cropping you can remove some of those soft edges at the long end.Might need to reconsider my views on this lens !!
