xaviergut
- Mar 22, 2023
The other day I tried to configure the two buttons located on the top and left side of the barrel of the Sigma 28-45mm f/1.8 lens with my Lumix S1RII... and it was impossible. None of the options that normally appear on the configurable buttons of Lumix cameras were available.
Then I realized that my Sigma lens didn't have the latest firmware update (1.1), so I downloaded the .plf file to an SD card and tried to update the lens using my Lumix S1RII. But to my surprise, the camera would start the installation process (the screen with the horizontal red bar) and then, after a second, the process would stop.
So I decided to research online and was advised to use the Sigma UD-11 USB Dock, which I don't own and costs around €50 on Amazon. But once I had it in my shopping cart, I thought I'd try updating the lens with another camera. So I put the SD card in the Lumix S5II and the update went smoothly.
I was also able to configure the Sigma lens buttons, since the Lumix S5II allows you to do that. Then, out of curiosity, I put the Sigma lens back on the S1RII and tried it again, and... it worked! So I decided to assign the left button on the lens to "aspect ratio." That setting was assigned automatically to both buttons, the one on the left and the one on top.
My question is: can different functions be assigned to those buttons, or are they only meant to work the same way whether the camera is in portrait or landscape orientation?
And another question: Is it possible to assign different functions to those two buttons using the Sigma USB dock?
Thank you!
Thank you!
