Leica did it again: new 2.8/28-70
RBecker
Leica introduced today the new Vario Elmarit 1:2.8/28-70 Asph.
By comparisons of technical data and the graphic of lens elements it is nearly identical in design to the Sigma Contemporary 2.8/28-70 introduced in 2021.
The Sigma is a great lens and worth to be a "kit" lens for Leica, but has Leica no own designs anymore? For the price of the Leica I would expect a little bit more than a new body with more metal parts...
To users of Leica lenses: Are the "cheap" designs build in Germany or build in Japan?
Interesting. I tried the Sigma 28-70 and it’s a great performer, especially at the price. How much are Leica asking?
The cheapest I could find locally in the Netherlands last month was €849. I think it is a great performer and an awesome lens. But the Lumix fits me better, and feels much more solid.
If Leica put a better and good sealed lensbody around that same optical formula, but with tighter tolerances and better glass and coating, and zoom in the direction it would be a really good lens. But not €1950 good. +€300 for the better build and materials, and +€100 for the logo would be fair against Sigma implementation. It would also mean a weight increase.
Already Found it… and it turns the wrong way also Z04 975but the rest I imagined right
The official price is 879 in Germany, but because of time the streetprice is lower.
Better? That is the question with all these designs from Sigma in Leica bodies. I know the great results from my Sigma lenses and I doubt I can see differences if I used the Leica versions. Maybe the mechanics is a bit more solid (maybe!), but the Sigmas are not bad at all.
That was the question about made in Germany or made in Japan: are these lenses build in Germany at Leica (only using the design) or are these lenses made in Japan, then with 99% by Sigma. I found no information which lens from Leica is build in Wetzlar and which in Japan…
I had the Sigma back in sony times and did not like the images. The 24-100 produced nicer renderings and colors.
Now I am happy with the 24-60... I think it is better than the sigma.
I agree, like my 24-60/2.8 also a bit more. Didn't use the 28-70/2.8 too much. I had bought a used one at an online store, which I returned after strange noises and slow af, and then bought a new one. But then the 24-60 got announced and I saw the review of @Richard Wong, and decided to return the Sigma within the grace period for full refund and place a pre-order for the 24-60/2.8. I'm personally glad I did. I would not sell the 28-70 for a loss to buy the 24-60 if you are happy with the Sigma anyway.
I have never had a Leica lens, but what I've seen they are more robust build then there counterparts. The announcement claims fully weather sealed for example. I thought that the Leica 24-70 is also a Sigma design? So it makes sense. But Leica build there lenses in Germany and Portugal in their own factory with extra tight tolerances and apply their own glass and coatings anyway, so it won't be exactly the same but comparable. But I have zero interest in a Leica lens for L-Mount anyway, for obvious reasons.
All the latest releases from Leica like 14-24, 24-70, 70-200, 28-70, 100-400 are at least based on the Sigma designs.
The build quality of Leica is maybe better, but the quality of the Sigma Art lenses is already very high! From my knowledge the 100-400 is made in Japan, so obviously build by Sigma. That is the reason why I asked where the other Sigma designs are produced…
I remember watching a YT video some time ago comparing the Panasonic 50mm f1.8 to the Leica 50mm f2. By all accounts they are the same optical design but the Leica lens has a more up-market metal build. The images from the two looked indistinguishable.
Yes, this belongs also to the 35mm
Here the difference is a bit bigger by the different max aperture, but this will also only end in a small change of mechanical design…
Anyway, I see it as a testimony to Sigma and Lumix, that it is (or at least the design is) deemed good enough for Leica. What I read as that due to the tighter build tolerances the sample variation of the Leica build lens is much smaller. But a perfectly build Sigma or Panasonic lens would therefore give an indistinguishable result.
The “cheap” designs are build in Japan or Portugal. I think the Sigma versions are made in Japan and the Panasonic versions in Portugal. It is rumoured that Leica is coming out with a new mirrorless S camera body and it is speculated that Leica is designing a new set of lenses to go with it. Could be, their design team is preoccupied.
When it comes to the L mount, the 21/2, 28/2, 35/2, 50/2, 50/1.4, 75/2 and 90/2, are definitely Leica designs. The 16-35, 24-90 and 90-280 are unique, but most likely designed by others. The rest are clearly versions of Sigma or Panasonic designs.
As far as I know are the 24-90 and 90-280 own designs and the 16-35 possible a Panasonic design. Also in the old days many lenses where not own designs: Minolta, Sigma, Zeiss and Schneider-Kreuznach come to mind. Don’t forget that Leica has become a niche player and does not have the facilities to design it all. The good news is that the rebuild Leica designs from other manufacturers are better and weather sealed. But you have to pay for this privilege in weight and money…
There is a Konica Minolta patent for a 16-35 that is identical to the Leica 16-35. The 2 companies used to work together before Minolta got bought out by Sony. The Panasonic 16-35 L mount lens is a very different design. There is a Panasonic patent for a 90-270 2.8-4 that also looks virtually identical to the Leica 90-280 2.8-4.
That said, lens design is only part of it, Does it really matter who did the design if it is a good design? Obviously you what the best optical performance that also meets other design goals like size, weight, af speed etc at a given price point. Lots of talented people out there.
For photography:No
For enthusiast who should pay way more: In my opinion yes
It‘s like ordering a Porsche or Ferrari and you get an Audi engine. Great engines, nothing to complain, but at the end, for the money (!), I would expect a bit more. The Leica optical designs where famous and now it looks like all the last lenses where not designed by Leica itself. Maybe the housings are a bit better than the originals, but I would love to something different. At the end we will get 3 50mm from 3 companies, all the same basic optics…
Ouch - versus about €750 for the Sigma. Can it really be almost three times better?
To me, Sigma can not beat Leica in optics, and overall craftsmanship.
Wherever Leica lenses are made, it's still a quality.
It is said, Sigma, and Leica are in fact two different lenses.
I think, I've found my perfect walkabout zoom. The price is not too steep for what this lens offers.
Comparing with similar Lumix S Pro 24-70/2.8, that costs almost the same as Leica, but, it's much bigger, and heavier, also not optically superior to Leica ... it's no-brainer for me.
And, I don't like the look of images shot with 24mm, or less. ... 28mm is my the widest preference.
