Kolari Magnetic Clip-In Filters for Panasonic Lumix (L-Mount)
xaviergut
Filter Effect options:​
3-Stop ND – ND8 (0.9) Neutral Density Filter
6-Stop ND – ND64 (1.8) Neutral Density Filter
10-Stop ND – ND1000 (3.0) Neutral Density Filter
Mist Diffusion 1/4
Mist Diffusion 1/8
550nm Infrared***
Blue IR/NDVI***
IR Chrome Lite***
Iridium – Color Enhancing
Clear – Dust Protective
UV/IR Cut Hot Mirror***
UV/IR Cut Hot Mirror Pro 2***
UV/IR Cut – IR Bleed Correction
Compatibility:
Kolari Magnetic Clip-In Filters for Panasonic Lumix (L-Mount) are compatible with the following cameras:
Panasonic Lumix S1
Panasonic Lumix S1II
Panasonic Lumix S1IIE
Panasonic Lumix S1R
Panasonic Lumix S1RII
Panasonic Lumix S1H
Panasonic Lumix S5
Panasonic Lumix S5II
Panasonic Lumix S5IIX
Panasonic Lumix S9
Leica SL2
Leica SLS2
Leica SL3
Leica SL3S
Not compatible with Leica TL or Leica CL series
How to install the filters:
...yikes.
I would not feel at all comfortable putting one of those on my sensor.
I'm quite
...yikes.
looks to me like it's 4-5mm away from the sensor. I think so long as you're careful fitting it then it should be pretty risk free.
Mist Diffusion 1/4
Mist Diffusion 1/8
550nm Infrared***
Blue IR/NDVI***
IR Chrome Lite***
Compatibility:
Panasonic Lumix S1
Panasonic Lumix S1R
Panasonic Lumix S1H
Panasonic Lumix S5
Panasonic Lumix S9
Leica SL2
Leica SLS2
Leica SL3
Leica SL3S
I could be tempted. It would mean I could use a 10-stop ND with my TTArtisan fisheye. Prices are not crazy either.
